Delivery to the network
is it possible to supply energy from the battery to the power supply network of the quattro inverter? If so, what settings do I need to make? Do you need additional equipment? The system is three-phase, built on 15 kVA quattro inverters
Yes you can feedback to grid if allowed. The programmed assistant used is ESS and you need the addition of a GX for control. This is the most popular way to do it.
ESS Start Page.
Unless you are referring to just injection like the Hybrid Generator System?
And neither if these are DIY systems by the way.
