Hi all, any ideas on this the charger is charging and seems to be working correctly however no output on read out, as in pic, any ideas? Thanks in advance
What is the target battery?
Is it possible that the BMS on the target battery has tripped the over voltage or over current protection? When that happens, it can look like there’s nothing there to charge.
Hi thanks for responding no bms, lead 12v to lead 12v.
My other unit (same as) reading fine, and this unit is defiantly charging output, it’s just no reading?
That’s odd. If a multimeter says there is battery voltage on the output side of the Orion, then VictronConnect should be reporting the same.
Yeah multimeter reading 12.5v up to 13.2v in perhaps 30 mins, I don’t get why it’s not reading. reset back to factory setting, but still know reading, Is there a way to force firmware update to see if that clears it?
