Please try and post a schematic diagram of your system, then it may be possible to determine this.
Generally: Isolated systems are required if there is no common negative connection, or systems need to be isolated due to electrical noise or a potential difference. On a Yacht, it should be possible to work with a common negative for all systems, and that should be grounded via an anode.
