I’d like to run a diesel heater (12V @ 15A peak, 3A continuous) and some lighting (12V @ 10A) in a garden outbuilding. It’s too shady for solar, but I can run a low-voltage, low-current line from the house. That can handle the continuous load OK, but not the heater startup if the lights are on, so my plan is to add a battery buffer.
Does this setup look sane?
Possible causes for concern:
If the smart charger tries to draw more than 10A from the house, the 24V transformer will brown out. Can I configure it for a lower maximum draw? (or, is it smart enough to limit itself to whatever current doesn’t cause voltage drop?)
If I have this right, then when the smart charger is in absorption mode, the battery (and therefore the heater, lights, etc) will actually be receiving ~14V rather than 12V. I can’t think of an easy way to design around this… but do I even need to?
All advice very welcome!
