VEuser
1
Can you specify custom battery voltages with Victron MPPT solar charge controllers?
For example, I have some large, custom LiFePO4 12S packs (43.2V nominal), can an MPPT be set-up to charge these?
Thanks!
P.S. Ignore possible use with a Victron inverter, that’s not how they would be used.
Yes, it is customizable the same as all the other victron products with charging ability. Just be sure to get one that does 48v batteries .
Instructions are here.
A video on cretaing a custom battery profile.
As a FYI you can run victron connect with a demo product and play with the settings before even buying a product to see the options.
