CT's vs VM-3P75CT
I’m new to solar and am installing a hybrid system where I can’t feed any power back to my power company on a split phase 240v USA system
I need to get accurate CT readings from my main to my Cerbo GX MK2 that is about a 125ft away, to control my two Multiplus II output to only what the house is using. I plan to bury ½ pvc and run either Victron CT sensors with extended wires or use a Victron VM-3P75CT which is better?
I am leaning towards the Victron VM-3P75CT from the internet research I’ve done, but do I need an Ethernet switch and what type? Why can’t it plug directly into the Cerbo?
The VM-3P75CT will be installed in my main panel so can I add a two-pole breaker panel to power the Victron VM-3P75CT on it’s own and install the .5amp inline fuse on the neutral since the lines I’m installing the CT’s on are 2awg wire?
If you are an advanced network engineer you can try to set the Cerbo and VM-3P75CT the IP addres manual
Or you can buy a simple/cheap router with DHCP for addressing
“Victron CT sensors with extended wires“ I think this does not work or accurate
You can connect the VM-3P75CT to the Cerbo through the CANbus using an ordinary network cable. This eliminates a switch/router from the mix. Don’t forget to use the CANbus terminators which come with the Cerbo and the meter.
What I read said that 125 feet is to long for a CAN cable port connection, to us ethernet instead, is this wrong?
I have no experience with switch/routers, would I need a constant internet connection for this or am I just using it as a switch before the Cerbo GX. I don’t always have internet at the site which is way I wanted to hard wire the VW-3P75CT to the Cerbo. Can this be done using an ethernet cable which I’m told is better that a 125foot CAN cable run.?
What network do you have?
You do not need a constant internet connection, it is a local network.
Info CAN bus
Starlink, but I can never send power back to the grid so I need to make sure the connections don’t lose signal which I why I want hard wire with no internet
Example
You need only 2 Lan ports
Found on the Starlink site
It has 2 Lan ports, are they used?
Thank you
@psthe4th I recommend you using the VE.Can route. It will be more stable than Ethernet (no external hardware involved) and 125ft are not an issue. However, I would personally opt for a shielded cable to prevent any electromagnetic interference on the way – just to be safe.
Ethernet and ve.can use the same type of cable. Perhaps it’s an idea to first try with ve.can. If unsuccesful you can always switch to ethernet.
Ask your dealer what he prefer VE.can or Ethernet
