Installed a EVCS (New version). As known the measured values are not accurate. This can be adjusted using the multiplier or the curve.
The qestion is : can the EM540 be used to ‘support’ the EVCS (or at the least the readings) ?
If so - how could this be configured ?
No luck… that means this isn’t supported right ?
