Hi, is it safe to connect a bodega cooler 12v XS55 directly to the load output on a mppt smart solar charge controller 75/15 ?
Thanks!
Thanks!
Since its a compressor fridge, most likely not possible.
My Dometic CFX35 is rated at 7A at 12V, due to the inrush current to start the compressor it did not run on the load output of a 75/10
How did you connect it then?
Directly to the battery
