Connecting more than three VE.DIRECT devices to a Cerbo GX
I have four Smart Solar MPPTs. Each has a VE.DIRECT output, however the Cerbo GX only has three VE.DIRECT ports. What is the method for getting more than three MPPT controllers talking to a Cerbo? Thanks in advance.
Hi use a good quality powered usb hub!
If you have the can models you can daisy chain them with a utp cable.
But the usb hub works well.
As you have 4 VE Direct controllers use VE Direct cables on 3 of them and a VE Direct to USB cable for the 4th. If more then a hub. It is all in the manual.
That’s what I thought.
Or try https://youtu.be/V857aKuUnVo?si=62RnAxc_D5abi-7I
