Confused about ve.direct and smart
Evening,
I have a SmartSolar 75/15 that i intend to use for a remote/offgrid outdoor shower facility. Panel will be a 100W solar grape panel.
I have a 12V RV water pump, that will be powering the water pressure, a propane outdoor rated hot water heater, and a 12V 30AH Lifepo4 battery, that I already had. I also intend on using a Raspberry pi 3, running VenusOS to connect to Wifi which will connect to VRM. As the battery is a no-name, i was thinking of getting a 500A smartshunt to keep track of SoC.
A few questions,
  1. In some documentation i see that the smart shunt has a temp sensor. Is this true? I am needing this information as the battery will be in this building year round and I need it to stop charging when it freezes.
  2. I can use the Smart functionality to connect the SmartSolar to the Shunt through bluetooth. Now how do I connect this system to the raspberry pi running venusos? Can I use a ve direct to USB cable? Which device do I connect this to, the charge controller, or shunt, or both? Or is this all wrong?
  3. I will also have lighting that will be ran off of 12V led lamps. Is there a way to turn these off after a certain amount of time through a relay?
  4. Would the battery smart sense be the only device I can use to get the temperature by the battery or will the shunt do this? (Kinda related to question 1)
    Thank you for all your assistance.
  1. You buy the temp sensor separately- but yes there is an option for it.
  2. don’t use the ve smart network if you are using a PI for a GX. The generator start stop is a great way to do that. Or node red if you like to program
  3. Yes with a relay on a Cerbo or a GX with a relay for signal only you can switch off the load based on time.
  4. The wired temp sensor can go into the mppt or the shunt if you get a cerbo then directly to that, they all transmit temp data to the GX. The sbs does not work with a gx in the system and does not transmit data to the vrm, it is designed for smart networks (those with no gx).
