I’m building a dual battery system for a 4x4. It will primarily run a 12V fridge, occasionally some lights, a 12V compressor and some USB charger points when camping. The vehicle is parked under cover when not in use, sometimes for a few weeks at a time.
The new system consists of a Smartsolar 100/20 (with 2x 110W folding PV), Orion XS and a 300A SmartShunt to manage charging of a 100Ah, 12V AGM battery. This battery will eventually be replaced with a 100Ah 12V LifePO4.
The SmartShunt requires its red power cable to be connected directly to the battery +ve terminal. This leaves the unit permanently powered. I am concerned about draining the battery when it stands for a few weeks.
- Can I connect the power cable downstream of an isolator switch that will power the whole system on or off? Volt drop should be minimal; there is about 50cm of 16sq.mm cable, a 100A fuse and the isolator switch between the two locations.
I really want to monitor both the starter battery voltage and the “house” battery temperature using Victron Connect. The Smartshunt can do one or the other, not both. I will set up a VE.Smart network to link the devices.
- Is it possible to use the Orion XS or the Smart Solar unit to monitor and share the battery temp while using the smartshunt to monitor (and share) the starter battery voltage ?
Thank you
