I just want to confirm my steps here for adding a second 24v200Ah Lithium Battery Smart to my system, seems to be working fine, but I want double check. ![]()
- Wired new battery to Lynx Distributor with 300A Victron Mega Fuse.
- Connected the batteries BMS cables together and to the Lynx BMS.
- In Victron Connect: Reset the Pin to 00000 with the PUK code (probably not necessary, but it prompted me to do it so I did.)
- In Victron Connect: I went into the Lynx BMS settings, added my 2nd battery and increased my system capacity to 400Ah.
- In Victron Connect: Set the battery pin code to my secret pin of my choosing (no longer 000000)
- Plug it into shore power and let the Multiplus-ii charge up everything to 100% and balance.
Anything else?
For example, should I clear history in my Cerbo GX?
Thanks so much!
