Configuring a Multiplus-II: Config Software? Connection?
Hello Everyone,
I’ve recently build a offgrid solar system around Victron hardware (BlueSolar MPTTs, SmartShunts, Cerbo GX) including a Multiplus-II 5000/48/70. While I have almost everything configured and working just as I expect it, one thing is not done yet: The Multiplus.
My goals are:
  • Set a SOC based shut off limit, that uses a SOC as reported by a SmartShunt.
  • Enable the Multiplus to be turned on / off by the virtual load switch of the MPPT.
I was a bit surprised to see, that I cannot configure it via Victron Connect through the Cerbos Wifi (after all, I was able to configure everything else this way). Now went through the documentation (Multiplus Manual, Victron Connect configuration guide for VE.Bus products, Cerbo Manual) to try and make sense of this. I have learnt so far:
Connection: The Multiplus can only be configured via a MK3 USB / VE.Bus adaptor or via the VRM-Portal (access to the VRM-Portal via a GX-Device like the Cerbo is apparently also ok). Access via GX-Device and Victron connect is blocked (anyone know why?).
Software: There are three (!) different softwares to configure a Multiplus:
  1. Victron Connect, although with a few limitations (documented in the Victron Connect configuration guide for VE.Bus products)
  2. VEConfigure which can modify all settings
  3. VE.Bus System Configurator for “advanced applications and/or systems with four or more Multis” (so more than the “all settings” that VEConfigure can do?)
Now I’m a bit salty about having to buy this MK3 USB adaptor, only to overcome what appears to be a intentional software lockout. (Especially considering that the path via Cerbo and VRM portal proves that configuration via a Cerbo is possible.)
My actual questions are:
  • Is there any way to load/store the VEConfigure config files via the Cerbo, without having internet on site? (Advanced stuff, like SSHing into the Cerbo would be acceptable to me.)
  • Which configuration program do I use?
  • Is it even possible to achieve my goals this way, or are there further limitations on the VE.Bus communication, that I am not yet aware of? (The section about remote controlling the Multiplus sounded a bit like there might be more arbitrary limits, but there’s not much information in the manual.)
Thanks a lot,
Wombat
P.S.: Above post may sound a bit unhappy, but I’m only posting about the part I’m having issues with. I am really happy with the rest of the system.
Fastest and easiest solution is spend € 64 on the MK3-USB adapter and use VE.Config. It’s a fraction of the investment you’ve already made.
It’s not a case of intentional lockout - it’s history and architecture and flexibility with these systems.
Normally the dealer that sold you the equipment would have made sure you purchased an MK3-USB with the MPII.
Hi and welcome.
None of the methods mentioned are a secret, it is quite well publicised (several topics about this on the forum as well), so it should not come as a surprise when researching a first build.
There are just some architectural limitations when it comes to vebus systems. Newer RS systems are different.
If you are off-grid or remote then a mk3 is always advised as it is a critical piece of kit when something goes really wrong. Victron connect and a mk3 can do almost everything, just not assistants.
It is not overly elegant but it works.
It’s typically rare to not have reliable internet or a mk3 concurrently, but can happen.
Maybe it changes some point in the future, but that is not something we have visibility of.
It’s one of the quirks of using these systems.
Yes already built in.
If you are using ess - ve config
Only used for three phase parallel and more complex multi inverter systems. Ultimaty is links into ve config to program each inverter (if you are using assistants)
Otherwise all the basics are done with connect.
Not for initial configuration, which I suspect was the question.
You can’t preload a config, it can only pull and store copies of configurations from an already configured system.
(the configs are firmware version dependent, so any update of the multiplus invalidates the backup config)
This isn’t a software lock, but something that has evolved over time.
Modern systems should remain backwards compatible for as long as possible.
But for reasons of efficiency and stability, deeper system changes must also be possible using the old software until the complete port to Connect is finished.
It would be wrong to produce banana software that only ripens once it reaches the customer!
True but there is already a feature and if the person can offer to SSH then they can set it up.
This can be done over the vrm without the MK3 it just requires a download and an upload - it’s just not live over the ve bus products. It is over the RS products.
So I would use this UI to download the configuration to the cerbo, ssh into it and locate the downloaded config file (where? is there a detailed documentation on Venus OS somewhere?), transfer it to a PC with Connect or Configure to modify it, and then the other way around to „restore“ the modified file to the multiplus?
I guess the usability justifies the price of an MK3. I‘ve ordered one now.
Maybe in future releases there will be updates to the remote console UI to modify the configs directly. I get that it’s a different mechanism compared to newer VE.Direct devices, but I still don‘t see why it should not be possible.
It has been discussed and the answer was - not for be bus products.
There are other Victron ranges that allow ota changes
Hi @Bastelwombat,
In my case, with a Cerbo GX and a Multiplus II, I have the Cerbo connected to the internet.
In VRM, I open my installation—the only one I have—and then go to Devices. I wait for them all to load, then click Remote Configuration (or something similar; I can’t remember the exact name). From there, I click Download Configuration. I save it to my computer and make all the changes I need to the configuration. Then I go back to VRM, to the same place as before, and click Upload. The new configuration is uploaded, and it works!
There are details you’ll need to check in the documentation, such as password prompts in some cases, restarting the Multi, the file extension and other things.
I bought the MK3 to have direct access as a backup, but I haven’t used it yet. In my particular case, it’s more convenient to do it remotely.
So I don’t know if I’ve missed something in your initial question, but it should be as straightforward as I’ve described and shouldn’t require SSH or anything like that. I don’t actually know whether you can do anything via SSH to download or upload the configuration to the Multi from there. But I assume not, or that it wouldn’t be easy.
What problem are you running into with VRM?
Regards,
VRM requires internet access. No internet, no VRM.
I understand.
I’ve always understood Victron Connect to be the friendlier, more straightforward access point for users, including advanced users, where the parameters are limited to those that are less likely to need changing and are less complex and sensitive for the system.
VE Configure gives you direct access to the more raw configuration of the system components, for advanced users and administrators. These are parameters that end users shouldn’t normally touch, because they’re not even interested in knowing about them.
Additionally, the MultiPlus can operate independently and is designed to be configured in isolation, without a Cerbo. The same goes for all or many of the products. I suppose that will lead to building a local, direct configuration system, like the MK3.
And I suppose functionality is added from there, such as the ability to adjust some parameters from the Cerbo, and then the ability to update remotely, but without changing the standard procedure for using VE Configure locally.
Could they add a button directly on the Cerbo to do the same thing as from VRM? I don’t know; it’s possible, but for some reason that’s not the case right now.
I think that, focusing on the solution, an MK3 is the simplest and most straightforward option, as others have already said.
The other option is to work with some kind of temporary connection system, whether via LTE, 5G, LoRa, directional wireless bridges between points, or whatever it takes. Even if they’re subscription-free and/or temporary, only used when you need to configure it.
For SSH, take a look at this document, section 3:
https://www.victronenergy.com/live/open_source:ccgx:commandline?do=export_pdf&rev=1587550695
Hope that helps.
Regards :waving_hand:
