I’m setting up an off-grid system based on a Multiplus II GX 8000/48 controlled by a Cerbo GX and its GX Touch screen, and fed by a EEL 280 ah 48V Lifo battery box that has a smart JK BMS inside. The battery is to communicate with the Cerbo via the VE.Can bus 1 (Victron VE.Can to Can-bus cable type B, terminated on both sides) but is not recognized by the Cerbo controller. I suppose the Cerbo is the second version since it has VE-Can bus 1 and 2 indicated on the device. There is only one battery unit connected to the Cerbo, all DIP switches on the battery box are ‘off’. The battery reports no errors in its application. Any idea?
Related topics
| Topic | Replies | Views | Activity | |
| EG4 LL-S not detected on Cerbo GX | 7 | 776 | 31 December 2024 | |
| Communication between Cerbo GX & Felicity LiFePo battery | 1 | 750 | 15 April 2025 | |
| 12v eelBattery with canbus | 7 | 210 | 30 November 2025 | |
| Anyone using Cerbo GX Mk2? 500kbs BMS-Can to 250kbs VE.Can | 1 | 622 | 14 November 2024 | |
| Cerbo GX MK2 to TAICO battery BMS issue | 2 | 120 | 4 April 2025 |
