Each smart solar connect to a VE Direct to USB which combine in a hub and are connected to one USB port on the CCGX.
Color controller is malfunctioning for a week now and constantly rebooting. Furthermore CCGX will not display solar charging information. CCGX also reported false notifications that the 12/3000 multiplus battery temperature warnings; the 12/3000 has been shut off over this time.
I seem to think the CCGX needs to replaced? It is 6 years old now.
Reconnected the cables and forced a reboot. Same issues reported as before. The firmware for the CCGX has not been updated for at least several years. I have gone ahead and ordered a replacement CCGX
I got a similar issue today after a DESS assistant install on my CCGX with 12V2000W Multiplus with “new” 12V 300Ah LFP-battery and 50W lamp, change of battery dont help
Totally firmware-updates before installing ESS
Now crippled with continuing warnings about Low Voltage and closing down and wake up for 1-2mins
No reboot helps
I got out a huge .csv from CCGX but how to read it??
