Non riesco a collegare il cerbo gx agli altri dispositivi Bluetooth. Gli altri dispositivi sono tutti in “rete “ fra loro ma il cerbo non li vede. Come posso fare?
If i understood correctly, you are trying to add the Cerbo to a VE.smart network?
This is not possible, the Cerbo can not connect itself to other bluetooth devices, you can only connect to it, from a phone for example.
So for example to connect an MPPT you would need to use VE.direct
@chrigu is correct.
Thanks
Thanks a lot
If @chrigu answered your question sufficiently please be kind and click “solution” on the post.
