No Bluetooth on Cerbo Gx
My new Cerbo Gx won’t connect to Bluetooth with any of the pin #s your supposed to try.
Connect to its wifi hotspot instead. There is a qr scan code on the side - or if your phone can’t do that then the name and passkey are also there
See the manual here.
It’s connected to Wi-Fi, I’m trying to get it to communicate on my new Touch 50 screen along with my smart shunt and MPPT controller.
Smart shunt uses a ve direct to ve direct cable and the screen also plugs in. The mppt the same unless it is a can enabled model.
The Bluetooth has no use for you there.
Excerpt from the manual i linked above.
Excerpt
