My B&G Zeus3S 12 plotters connect to the boat LAN over WiFi only, and the Victron MFD app tile has never appeared on them. The Cerbo (Venus OS v3.81) announces the tile using its 169.254.x link-local address, which WiFi clients can’t reach, even though it also has a normal LAN address.
As a test, I resent the Cerbo’s announcement with its LAN address instead, as a subnet broadcast (e.g. 192.168.1.255:2053). The tile then appears, and the app works with live data over WiFi. A Signal K plugin (signalk-navico-embedder) that adds MFD tiles fixed the same problem the same way.
Request: could the Cerbo announce its LAN address and also send the announcement as a subnet broadcast? That would make the MFD app work on WiFi-connected Navico plotters with no extra cabling.
