I had my new Cerbo GX working just fine, then it lost connection and won’t connect again.
I then “forgot device” and tried to pair again. It will take the pin, then get to 80% of the connection process and stall and never complete connection.
How do I fix this?
power cycle the GX unplug power, plug back in, then try to reconnect
I unplugged the GX, noticed it was no longer available in the Connect app, plugged back in and tried to pair. Same result. It gets stuck at 80%.
Other suggestions?
Then when I try to go back to connect again, it gets locked up at 0%.
Wifi doesnt work either?
I’m not certain how to access with wifi.., thought it was just through BT
I can use my phone to access the Cerbo through WiFi?
Yes you can, you have to connect directly to the cerbo hotspot, unless you have disabled that in cerbo settings previously
