Hello, I have a cerbo s-gx on my system that occasionally if my internet drops disconnects and will not reconnect without resetting the network settings. This happened today. I pushed the reset button on bottom like I always do, but now my Bluetooth won’t come on to reconnect in Victron connect. Is there another way to get the network settings back in or someway to get the Bluetooth working again? The firmware was recently updated on my cerbo.
Hi. As per the note in the manual, does your Cerbo fall into the affected serial number range?
For Cerbo GX units with serial numbers up to and including HQ2207, internal Bluetooth is disabled when CPU
temperature exceeds 53 °C. In such cases, a USB Bluetooth adapter is required for reliable operation. Units
with serial numbers HQ2208 and later, as well as Cerbo-S GX, are not affected.
No mine is HQ2225
Fixed it reset it by unplugging the cerbo and plugging it back in. Thanks for your help.
