Cerbo GX venus os 3.67 - BMS disconnects
I have an issue on v3.67, which was not present on v3.66. I occasional see BMS disconnect messages and loose my battery information. I have to reboot the CerboGX to reestablish BMS connection. The Battery / BMS is SOK 314 Ah, connected via BMS-CAN.
All is good and stable on v3.66. I’ve had to roll-back the firmware to get a stable system.
Anyone else see BMS connectivity issues on 3.67?
3.68?
I can’t find any information about that.
No announcement on Victron professional or the Blog and no changelog.
Also not the FW files in the Dropbox.
I also checked for updates on a few of our systems, all say that 3.67 is the current version.
As far as I know there is also no 3.68 Beta.
Never change a running system.
If you don’t have problems with your system than you don’t have to do updates.
You also should disable the automatic update if enabled and check the changelog before updating.
For now you should leave the system on 3.67.
Sorry, I had the wrong versions….. The issue presented itself on v3.67, I rolled back to 3.66.
4 posts were split to a new topic: 3.67 smart BMS disappears after update
