Librewolf is basically Firefox and it worked fine until sunday. Except for the Cerbo GX there is not a single issue anywhere, and as mentioned above the Geolocation test page confirms the correct settings. This is not a critical, but a mere cosmetical issue, but I also question the idea behind it to map device time to local time. This is done nowhere else in IT, and for good reasons.
Regarding the SD card: It doesn’t matter what the system expects, it cannot STOP BOOTING. This is a critical issue as it causes a system failure days/weeks/months after inserting the SD card.
What spec are you referring to? The manual just states
“The internal buffer can hold logs for several days. To extend this period, insert a microSD card or USB stick. Check internal storage status via the settings menu. When external storage is inserted, internally stored logs automatically transfer to it, ensuring no data loss”, and
“Storage Device Requirements
• Supported file systems: FAT (12, 16, 32), exFAT, ext3, and ext4.
• MicroSD cards (SD and SDHC types) up to 32 GB typically come pre-formatted with FAT12, FAT16, or FAT32 and can be used
immediately. Avoid reformatting them to unsupported file systems”
I don’t see any requirement for it not to contain a DCIM folder. It was recognized and used by the software, so it is fine. I know that I can reformat the card, that is not the issue. The issue is that the system FAILS. If it was a delay, it was longer than 10 minutes, because that’s when I started cold booting the Cerbo GX.
I have seen the support chain on the Victron web page. I am not reporting a bug regarding the handling of SD cards to a spanish solar shop, this is not an installation or hardware issue. I checked the support page, and I didn’t find anything to open a ticket or submit a bug. Googling coughed up nothing. That’s why I wrote in my first paragraph that this is the wrong place to submit this issue. I have just re-read the community guidelines, there is not a single mention of tickets.
Don’t get me wrong, I appreciate you guys replying, but there is clearly something wrong here if I am not able to find the spot to place a ticket. It might be me, of course
