Cerbo GX deducting from AC loads and adding half to input
Cerbo GX Firmware 6.2 ( tried others)
2x Multiplus II in Parallel
Smart Shunt
DC Shunt
Problem is running only AC loads everything is fine
Allow battery charging it deducts 1/2 the current going to the AC load on the display. Then another 1/2 is added to the AC input.
Example:
1000w input , 1000w load, 0w charging the input and load display correctly
1000w load, 500w charging. IT will take way 250w from The Load display 750w.
It will add 250w to the input showing 1250w.
However the real input is 1500w. The load is still 1000w + 500w for the charging;
First picture is a set load that does not change during any of these screen shots;
