After asking some questions here today about our EasySolar Inverter system I have been going through everything (but not touching or changing anything) and have found that the CCGX is on ver 3.60 !
Is this of concern? or at least enough of a concern to downgrade the firmware to v3.55? If the CCGX is left at 3.60 will this be the cause of any KNOWN issues?
What is concerning me is how did this CCGX get the ver 3.60 firmware on it? Do these units do automatic updates ? Reading around here it says Victron has limited these devices to only going as far as 3.55 and that the only new firmware for these CCGX’s will be critical bugfixes and may result in a ver 3.56 for example.
So how on earth did this CCGX get onto 3.60 ?
Other issue is the multiplus 5000/48/70-100 (older model) is currently on firmware ver 474. Latest for this inverter is 557. Reading around here the advice seems to be if its working ok and doing what we need then dont touch it. Would that the be the recommended case here ?
