Hi I´m planning to use a Geothermal heat pump and the utility company can install a second one phase 220v supply. This means that I need to use both 40A 220V supply simultaneously. If I use two interconnected Multi RS solar, (or Quattro), Can I connect one AC supply to each inverter? Does this work? If not, is there a way to use the two AC supply simultaneously?
Thanks.
You could have a charger on one and the inverter on the other.
But one system cannot synchronise to two sources unless magically they are synchronised.
The Multi RS cannot be parallel connected yet.
And the quattros could be parrallel connected but can’t synchronise to two sources.
