Can I Use 240 Generator as AC Power for Multiplus-II 2x120v
My off grid system has a 240v diesel generator for winter use when solar is limited. Can I connect L1 & L2 of the generator into a Multiplus-II 2x120v? If so is this the only multiplus that I can use my 240v generator with?
Wiring Diagram?
Thanks
Always a good place to start and should answer your question?https://www.victronenergy.com/upload/documents/Datasheet-MultiPlus-II-3kVA-2x120V-EN.pdf
