Can I program two Multiplus II 180 Split phase through the VRM portal via System Config/VE Config?
4rvfun.com
(Nathaniel)
1
MikeD
(Mike )
2
This should be possible, but best to try this while you also have local access, incase it goes wrong…
Related topics
| Topic | Replies | Views | Activity | |
| Multiplus II 12 V 1200 watt Split phase? | 2 | 74 | May 15, 2025 | |
| VEConfigure Fernkonfiguration geht nicht bei Dreiphasigen Multiplus2? | 3 | 103 | October 26, 2025 | |
| Split phase on two MultiPlus‑II 48/3000/35‑120 V units not working | 4 | 97 | February 19, 2026 | |
| How to change the charger settings for Multiplus-II in parallel using VRM remote configure? | 39 | 714 | December 29, 2024 | |
| 3 X Multiplus II Changing from single unit to 3 phases system | 4 | 199 | May 23, 2025 |
