Hi there,
Very grateful for any help. I cant tell if this is a bug (as in this should be present) or a feature enhancement, as in its not there but could be added.
In the Overview of my Ekrano GX using new UI on v3.75 there is a button for “Controls”
Within that I can see a list of controllable devices, and in my case my inverter is there, and my users are used to going there to Control devices, e.g. tunr inverter on and off.
However I also have a Skylla IP65 Inverter which is a “Controllable Device” as are the Orion XS Alternator DC/DC Chargers.
Should those devices not also be available in the list for convenient on/off control? I would note that as the inverter is ve.direct and the Orion XS are ve.direct it seems that it should be possible, whether the Skylla with its ve.can connection can be handled remains to be seen, but given that the control is possible through other menus its seem reasonable that it could be made available in the controls menu.
The same of course would apply to the VRM Controls window too.
Many thanks for considering this enhancement,
