today (from about 12:00 CET) stopped returning “bs” part (info about SOC)
Returns only this information:
I’m seeing the same issue, would like confirmation its a bug and not a planned change from the overnight API mods.
I can get the bs and bv tags with a custom datatype:
Good morning,
You can get the bsattribute if you query live_feed_extra, for example https://vrmapi.victronenergy.com/v2/installations/…/stats?$type=live_feed_extra&interval=hours&start=1763506800&end=1763593199. The endpoint was split into two.
Kind regards,
Lucian
Hi all,
We’ve reverted the changes done to the live_feed type; you can safely use this again.
With kind regards,
Jarco
