Bug: GUI V1 empty and GUI V2 black on Cerbo GX & Raspberry Pi since Venus OS 3.60–3.64
I would like to report a reproducible issue that affects both Cerbo GX (Einstein) and Raspberry Pi GX installations since Venus OS ~3.60 (definitely in 3.64).
Problem description
On both Cerbo GX and Raspberry Pi systems running Venus OS 3.64:
    • GUI V1: only shows empty frames, no content.
    • GUI V2: screen remains black, sometimes only “Advanced” is visible.
  • As a result, the device becomes unusable for configuration or setup.
  • This was reproduced on three independent devices:
    1. Cerbo GX #1 (no auto-update, no SSH) → completely unusable.
    2. Cerbo GX #2 (auto-update enabled) → same problem, awaiting a fix in future release.
    3. Raspberry Pi with Venus OS 3.64 → same problem.
Workaround
  • Downgrading to Venus OS 3.55 via SD card reinstall immediately restores both GUI V1 and GUI V2 functionality.
  • This confirms the issue is firmware related, not hardware related.
Severity
  • For existing, already-configured systems the bug may remain unnoticed, since the devices keep running normally — the limitation is that settings can no longer be changed.
  • For new devices / first installation this problem is critical: initial setup is impossible with Venus OS 3.64.
Request
  • Can Victron Engineering please confirm whether this bug is already tracked internally?
  • Is there a planned fix in Venus OS 3.65 or a later release?
Thank you for your support and for confirming.
Best regards, Matthias.
Are you running any third party mods ?
I have a Cerbo and RPI and neither are experiencing these issues on v3.64 or v3.70 beta versions.
One of the 2 cerbos is brand new from the factory. Nothing installed yet. Only updated to newest firmware and it was basically unusable until I downgraded again (that’s why it’s such an issue).
the other cerbo is also running only stock firmware, on the raspi I installed DBus serial battery, but removed it again. No difference. Only a downgraded helped there as well.
