Bmv Doesnt show up on VRM Possible BUG
After the last update Bmv 600-S cant be seen on Victron Connect
Phone Android
Venus Os on Raspberry
Any Ideas or a bug.
Any Ideas or Any real Victron employee watch on this issue?
I can see the BMV on VRM, I can See it on Device List but Victron Connect doesnt see it.
Thank you for reporting this. We will look into this issue.
With kind regards,
Thiemo van Engelen
Similar problem on my other installation
843826 Siteid
Smart Solar Mppt 150/45 rev3 Showing on VRM but not on Victron connect via remote.. Cant Access it, not showing up.
Removed and reinstalled VRM mobile not worked.
Same problem on PC Victron Connect.
Hi @heraktitus
Do you still have this problem with the MPPT? If so, what version of VictronConnect do you use? And can you perhaps create a service report and post that here?
With kind regards,
Thiemo van Engelen
VictronConnect_report.log (48.4 KB)
This is Log file for 843826 Siteid
Mppt 150/45 rev 3 Showing on Vrm, but not on Victron Connect
Multiplus II and Bmv 712 is visible
Victron Connect Version 6.23
Running on Cerbo
This is the log file for BMV 600S
It is accesible via VRM, but cant be seen on Victron Connect
VictronConnect_report.log (46.6 KB)
Site ID 755329
Same on PC cant be accesed
Running on Raspberry Pi Latest stable version
Hi @heraktitus
In the service log of the MPPT, you are connecting to the site GGAda, but the siteid you mention in you post is for site GGBalkon. Can you please create a new service report after connecting to GGBalkon?
With kind regards,
Thiemo van Engelen
Hi @heraktitus
We have found where the problem lies with the BMV600. This is a regression in VictronConnect and will be solved in a future version of VictronConnect, but it is unknown when this will be.
With kind regards,
Thiemo van Engelen
Ok Thnks For The 600S Problem.
The Mppt problem is in GGAda Site id 58229 (Sorry maybe in the first post i mixed with other installation id)
SmartSolar Charger MPPT 100/20 48V The problem is in this device
VictronConnect_report (2).log (39.9 KB)
Hi @heraktitus
Thank you for this new service report. We were able to determine the problem and I am sorry to report that this is also a regression in VictronConnect which needs to be fixed in a new version. In the mean time there is unfortunately not much that you can do to work around the problem.
With kind regards,
Thiemo van Engelen
Ok no problem at least Victron aware of the problem and it will be fixed in the future.
Thnks.
