Bmv-712 shows wrong current
The classic reason that crops up time and time again in a boat or vehicle is the chassis / hull ground is connected to the domestic battery negative terminal that is being charged by the Orion, hence the charge current for the domestic batteries does not go through the BMV 712 shunt. The chassis / hull ground MUST be attached to the system side of the BMV712 shunt.
There is a FAQ in the DIY section covering this.
