BlueSolar MPPT 75/15 cannot communicate with VE.Direct over USB
Hi, I appear to have an older MPPT with no bluetooth and wanting to update the firmware with the latest to connect to CerboGX. I ran into an issue connecting to the device with the VE.Direct cable (USB). Although the logs detected the device, it was not able to communicate normally. Any suggestions to overcome this issue?
From debug logs in VE Power software
[normal] [14:59:45] Scanning for VE.Direct products on COM3
[debug] [14:59:45] [VE.Direct] checking port COM3
[debug] [14:59:45] [VE.Direct] port open
[debug] [14:59:45] [VE.Direct] hex: ping
[debug] [14:59:45] [VE.Direct] thread start
[debug] [14:59:45] [VE.Direct] hex: get device id
[debug] [14:59:45] [VE.Direct] found MPPT (PID=0xA07D)
[debug] [14:59:45] [VE.Direct] hex: get register (0x010B)
[debug] [14:59:45] [VE.Direct] internal model name=“BlueSolar Charger MPPT 75/15 rev3”
[debug] [14:59:45] [VE.Direct] hex: get register (0x010A)
[debug] [14:59:45] [VE.Direct] internal serial number=“HQ24227FZMN”
[warning] [14:59:45] [VE.Direct] serial port error [system]: The I/O operation has been aborted because of either a thread exit or an application request (995)
[debug] [14:59:45] [VE.Direct] thread stopped
Ive never used that, is it not obsolete by now? Anyway, with VictronConnect it should work
