Hi all, I have installed Lithium battery on board which also drives an electrical anchor winch. In order to protect the battery to be discharged completely which will damage the battery I have included a Battery Protect from Victron. Will this properly work of can I expect issues while using the winch? Thanks for your feedback and advise.
Reg, Ronald
Hi Ronald, welcome.
Can you please say which model of battery protect and the amps that the windlass motor uses?
Thanks,
Alex
Hi Alex,
Thanks for te response.
I have the Battery Protect 12V 220A and the normal current expected is approx 50 to 60 Amps from the the anchor winch Lewmar 1000 Pro.
I made a short test with the setup and the winch seems to work properly without any disturbance in the power from the BatteryProtect.
Regards, Ronald
