Battery details screen
Hi anyone can help me understand what doesn it mean this screen. why do I have 2 modules blocking charge and no available capacity info.
If they are blocking charge - they don’t want to be charged. Not really a problem as they are reporting 100%
The installed/available is a funny variable between manufacturers. Many don’t bother to get that right.
4 are online so they are all communicating the basics ok.
What batteries are they?
Looks like SUNWODA.
I think not all available Victron dbus values are supportetd (filled) by the battery BMS.
If the battery charges to SoC 100 and discharge correctly, all is fine.
As example: Pytes serves all fields.
@Pppraia
Please make a screenshot if SoC is lower and the batteries are in charging state.
Thanks for sharing. It also looks like other batteries i have seen so couldn’t point to a specific one. So not unusual.
Thank you for your answers so far much appreciated
Indeed sunwoda
why there is a big difference between the low cell voltage and the highest cell voltage
I saw somewhere that the maximum value between these values should be 0,05 volts and a bigger value could mean a cell balancing “issue”
Can vary from manufacturer to manufacturer. So really may be a piece of useless information if it wasn’t stated by the battery make you have.
With SoC 97% and discharging
@Pppraia
You can ask the Sunwoda Technical Support how their BMS supports the standard BMS-CAN and what are the Sunwoda LFP balancing parameters.
50 mV difference in cell voltage is no problem I think. This are very dynamic values, if great currents occure while dis/charging the voltage difference rises up, at lower currents the BMS balances and the difference will be lower.
I think all is running fine. Only some dbus values (BMS-CAN values) are not be supported, no problem. :slightly_smiling_face:
And if one or more battery packs are at SoC 100 the BMS send these packs as ‘blocking charge’, but only at THIS moment. They are functional.
Ok Thanks :blush:
