I myself switched from Daly to JK after 8 failures. Was getting a little too expensive. Yes. You may receive a free BMS from Daly, but if your batteries are over(dis)charged….you will still have to replace them from your own wallet.
With some BMS’s having pretty poor SOC calculations (the DIY ones often the worst) people have resorted to shunts instead. You lose management, but management with a hopeless SOC isn’t worth all that much.
How you configure a BMS does matter, but if it can’t accurately measure what’s going on in the battery, it will never work properly.
Have a look at Orion as well, it is pretty decent.
No BMS is perfect, just some are less imperfect than others.
Well aware, just commenting that this is more common with DIY batteries.
Pace is a common generic choice for many cost-effective batteries, even some supported by Victron (BSL, Hubble etc).
It is used because it offers quick and easy integrations into popular inverters, but it has issues which are seen across these different brands to varying degrees.
How it behaves can also vary on how you use it, so it may work fine in one application, or rather go unnoticed, but in another it has issues.
