Batrium trips the MCB at 39% SOC
My Batrium trips the MCB at 39% SoC. There are still 49 volts overall and 3.063 volts per cell left. So the voltage is okay. But in terms of SoC, it seems wrong. Any ideas?
What’s supposed to be wrong or right about that? The MCB has absolutely nothing to do with the SOC. What is the MCB responsible for in your setup? …
Yeah, the question doesn’t belong in the Show Your System section. Sorry.
3
That is damn low. It is correct for the MCB to trip (at least with the default Batrium configuration).
If the system deviates that much, then either you have configured something incorrectly in the shunt or entered the total capacity incorrectly. The Batrium shunt is highly accurate and there is little deviation. The only exception is if you haven’t fully charged for several months.
Conclusion: Check the configuration.
It’s ok. I moved it to DIY. You are all good here
Hello Jens,
Thank you very much for your reply.
I know Batrium’s software and app. I’m less familiar with the configuration. This has been causing me problems for weeks. What do I need to change, and where, so that the SOC is around 10% at 49 volts? And not 39% SOC.
Kind regards,
Zen
I can’t answer that with 100% certainty. Quite a bit of information is needed: which cells, how many, what charge/discharge rates, and screenshots of the current settings.
Lf280k, 48 cells configured as 16s3p. I’m not exactly sure what the charge and discharge rates are. And I’ll send you as many photos as you like, once I know which ones you need.
Why not ask on the Batrium forum ?
Good idea,
I didn’t know there was a dedicated Batrium forum.
Thanks
It’s not exactly busy on their, and James will likely offer a (paid for) remote “consultation”
