Hi fellow members,
With automatic translations now enabled there are likely to be some questions about how to customise this to individual needs.
At the top right of your session is a localisation setting which should be set to your preferred localisation language that the community supports.
If you select your avatar, choose the bottom, profile, option:
Then choose “preferences”, followed by the “interface” tab.
Here you can add all the languages you are comfortable with so the translator does not automatically translate those for you.
You can also untick the “automatically translate topics and posts in other languages” option, which will disable this feature completely:
Translations can also be toggled on individual topics, at the top next to the post date.
Changes will apply to new topics and to the last 2 days of topics.
