Before the update AI powered proofreading and topic title suggestion was available. Was that removed intentionally?
That actually isn’t theme-related, there is a fair amount of change happening with agents so access to them beyond moderators and staff has been temporarily removed.
Once clean up and changes have been done on the platform side, it will be phased in.
Can you give me an idea of your ideal use case for these tools? I can look to prioritise those.
Moved to a dedicated topic
Yes, I thought so because it disappeared in the old theme as well. But since this happened at the same time the theme changes were made, I figured it might be related.
Regarding the use case - there’s not much to tell. I used the proofreading feature from time to time since English is not my first language. Very helpful little thing. Not that I absolutely need it, but it helped add commas here and there and make some minor adjustments to the text I posted.
It will be back. They have made a lot of changes so just need to absorb those.
From a translation perspective don’t forget we support 7 languages so you can pick what you are comfortable with and let the system do the rest.
This should be available again now.
