my client had:
Charger: Epsolar Tracer 10420AN MPPT 100A
i sold him:
Inverter: Victron Multiplus-II 48/5000/70-50
Battery: powerESS Sunlight 48V/5.12kWh Stack
i want to program the inverter via VE.config in order to achieve the following rules and in AC2 i connected an air conditioner:
AC2→relay on →SOC >75%
AC2→relay off →SOC <70%
the general idea is that if the air conditioner runs i want to protect the system from drying up the battery_charge.
the problem that i have now is the fact that battery monitor inside of inverter refreshes the battery charge (SOC Value) if and only if i connect the inverter to the grid or via generator. the calculation of the SOC is updating if and only if there is a charge function [AC-IN Active]. as i understand it i need to add a Cerbo_GX to the system in order to communicate the Battery_Bms←→ Cerbo_GX←→Multiplus.
is there a way to achieve that without the Cerbo_GX?
thank you
