After updating the Cerbo to V3.80-32 no Solar edge in VRM
Na de Cerbo te hebben geupdated naar Beta V3.80-32, is de Solar edge omvormer in het VRM verdwenen.
De omvormer levert gewoon terug, wordt gedetecteerd door de Cerbo, maar onder apparaten is de verbinding verbroken. Dess hou wel rekening met de opbrengst. Lijkt een weergave probleem….
Wordt wel gewoon geladen, wat zou de oorzaak kunnen zijn?
Thanks for reporting. I guess that is system 363750, right? (the number in the url)
It does look like there is something unexpected, but not sure about the cause yet.
There was an update on the Solar Edge driver, mentioned here.
Apparently there is a side-effect to that change which affects your system. The temporary fix is to boot back into the previous firmware, while we try to find the cause of that and fix the underlying driver for the next beta.
Yes, thats the one.
The problem was actually introduced in v3.80~16. v3.80~32 should have fixed it, but the fix wasn’t included. I updated your system to have the fix. v3.80~33 will include it for everyone.
