Cerbo is on V3.72.
Hi
When running the upgrade to V3.73, everything looks OK and I get the message of successfully installing the firmware.
…but after a reboot the Firmware is still showing V3.72
I have tried to update to the latest beta ( currently V3.80~25).
…but as before, after reboot the CerboGX reports firmware V3.72
any ideas here?
M_Lange
(Matthias Lange - DE)
May 29, 2026, 5:16am
2
I would leave it as it is (never change a running system) or I would try to install the FW via an USB stick.
I am usually on the beta releases.
I am not afraid of bugs and try to help in any way I can.
nickdb
(Nick)
May 29, 2026, 5:43am
4
Have you checked for disk free space?
Do you have any other tools or mods loaded on the GX?
Image type “Normal”
I found some error at the TCP server:
I do not believe this to be related, but who knows
jeroen
(Jeroen)
May 29, 2026, 1:31pm
6
Did you run the installer image recently? Likely you need to format the sdcard and not only remove the files on it.
I only tried to install from the GUI.
via the “Press to update…”
There is an empty SD card installed which I will now eject.
Nope, that did not change anything
After successful install and reboot: still on 3.72
jeroen
(Jeroen)
May 29, 2026, 3:35pm
9
So you physically removed that sdcard?
jeroen
(Jeroen)
May 29, 2026, 3:37pm
10
Please remove the SD-card first and reboot before updating.
Good morning
1st I did a reboot with the EJECTED SD card, but NOT removed.
Result as before, NO update of the OS
2nd I did as recommended, I physically removed the SD card and rebooted -
RESULT, it rebooted into V3.80~25 - without installing
I guess it somehow found the new image from a previous install attempt.
However, the firmware upgrade worked
Thanks for helping and best regards
Jurgen
