Advice on connecting stiff 70mm² DC cable to MultiPlus-II 48/5000 (Belgium, AREI)
Hello everyone,
I’m currently installing a Victron MultiPlus-II 48/5000. According to the documentation, 70 mm² DC cable is required, so I want to stick to that.
To comply with Belgian AREI regulations (cable in a duct/bundle), I chose a B2ca RZ1-K 70 mm² cable (Topcable). However, I’m running into a problem: the cable is so stiff that making the bend to the MultiPlus terminals almost mechanically stresses the clamps—not ideal.
The classic flexible welding cables (H01N2-D) or battery cables are much easier to handle, but as far as I know, they do not have the required fire reaction class for this type of installation.
My questions:
  • How do you guys handle this so that it fits physically and stays AREI-compliant?
  • For a 48/5000, is 70 mm² really necessary? I often hear that 35–50 mm² is actually sufficient.
Any tips or experiences are welcome!
PS: I’ve attached a photo showing the furthest I can bend the cable without putting too much stress on the MultiPlus terminal.
PS2: Yes, I know the AC side is currently using H01N2-D. That was a mistake on my part and it will be replaced before inspection as this is Eca cable that is not allowed in ducts or bundles.
Nice build the biggest issue I had with 95mm2 is the lug as you can’t get it square on with the cable so I use a cone bit to taper the lug so it can just be ribbed over the threaded bolt and I would say if you could warm the cable it may help you out too
tapering the lug might indeed just give me the marge i need to get it over the thread. the straighter it gets, the more easy it should go.
I’ll test with the current testcrimp before cutting away at my multiplus.
Let us know how it goes
I got it on there after tapering the lug. Wonderfull. (Yes i know I need to crimp a new lug to the cable)
But now i get the next issue with this cable not being flexible enough. I made some 3D printer molds to force the cables to use the biggest radius there is available. Guiding me in how to bend each cable.
But i just cant make the bends that i need.
Any of you have any experience with cabling in Belgium?
The Victrons manual states that I need a 70mm² cable for MultiPlus-II 48/5000 class 6
Belgium AREI (Inspection of your electrical installation) requires that cables in ducts are rated Cca (fire rating)
Issue is that a Cca class 6 cable does not exist. So the cable I have is class 5 but this is just to stiff to bend.
My question what cable are you useing, and did it get approved in Belgium?
I moved away from the class 5 cable. And changed it out by class 6 cable.This is not Cca rated but will see what the inspection states.
