Advice Needed: Switching from 3-Phase to Single-Phase Setup
yes, basically the problem is solved.
I don’t need 3 phase, since I don’t have 3 phase devices.
Connecting the inverters in parallel solved the problem.
For many month I don’t need to worry if this or that is connected to connect something else. The most worry I had was the car, but it lowers the power to charge, if the house needs power elsewhere.
Good to hear you got it solved for your use case. I do think there is a broader topic that is interesting to discuss based on your original question, one that I will revisit when our own single phase 40A 230Vac mains gets upgraded to three phase 3 * 25A mains.
Hello Jan,
your reply re-triggered a former question I had in another thread on having asymetric loads in Delta-configuration with Victron MP, which sounds pretty much to be an open Delta.
Can you confirm that the MP can handle this?
Thx in advance!
I’m sorry Thomas but I’m not confident enough to say either way, not until I"ve been able to do more testing myself anyway.
