I have 24v system and currently have a MPPT 100/30 charge controller connected to the Lynx distributor. But want to add Ground solar array. So th 75/15 or 100/15 charge controller would be perfect. But I don’t know how to add it to the lynx distributor because I can’t find a 25A MEGA FUSE? Let alone 40A MEGA FUSE for the MPPT 100/30 charge controller.
How can I connect the 100/15 charge controller to the Lynx distributor?
Use 40A cable, you can get 40A Mega fuses, link to a UK source, not sure where you are.
Thank you for your info.
But I was looking around and found someone using an inline fuse using 10 awg wire with a 25amp fuse. Will tap in to Lynx distributor@ far end of Lynx.
I really do appreciate the quick answers though.
CIP138040020 is the Victron 40A megafuse rated for up to 80V systems.
