AC coupled Fronius Symo not shown on GX device pages GUI
I have a GX device and an ac coupled Fronius Symo 8.2-3 pv inverter running. The inverter is correctly discovered and shown in the GX device settings. However the device is not shown on the pages overview. I don’t have an idea, what the problem could be.
All firmwares are up to date. The configuration looks correct. Does anyone has an idea what is wrong with this setup?
Thanks
You don’t appear to have a victron inverter, or it is off. Those dash displays are built around an inverter being presented, so I suspect that is the problem.
Right, The Multiplus is not yet up and running. I wanted to setup the system stepwise. GX device + pv inverter was the first minimal step and I would have assumed, that this is enough to show the pv inverter.
If this isn’t the case, I proceed to install the Multiplus.
