Behavior of Victron system (Cerbo GX + Quattro II) when AC-coupled Fronius GEN24 is electrically isolated for an extended period
Setup
- Multiple Quattro II 48/5000 in parallel (single phase)
- Cerbo GX
- Pylontech LV Hub + multiple US5000 batteries
- Multiple MPPT RS 450/200 and MPPT RS 450/100 (DC coupling)
- Carlo Gavazzi ET112 energy meter via RS485, configured as AC load role
Project context
We are planning to add a Fronius GEN24 Primo 8.0 or 10.0 (single phase, non-hybrid, MG50) as an AC-coupled PV inverter on the AC-Out of the Quattros, following the Victron AC coupling documentation and respecting the Factor 1.0 rule.
The Fronius will be installed in a separate outbuilding (barn), connected to the main AC-Out bus via a dedicated circuit breaker. This breaker may be opened independently — for example during electrical work on that outbuilding — without shutting down the main system. In this scenario, the Fronius would be completely de-energised (no AC supply), therefore powered off and unreachable on the network (no TCP/IP), for an extended period ranging from a few hours to several days.
Note: we are aware that the GEN24 (non-hybrid, standard grid-tie) is anti-islanding by design and will not produce anything without AC present, even with PV connected and sun available.
Questions
Alarms: Does the Cerbo GX generate an alarm when the Fronius becomes unreachable? If so, which alarm exactly, and is it configurable or mutable (severity, delay, disable)?
Quattro behavior: How do the Quattros behave when the Fronius they were configured with suddenly disappears? Do they enter any degraded mode, generate errors, or change their charge/discharge strategy?
Duration and conditions: Does the behavior evolve depending on how long the Fronius has been absent (e.g. 1 hour vs 3 days)? Does it matter whether there is DC PV production from the MPPT RS at the moment of disconnection?
GX display: How is the absence of the Fronius represented on the Cerbo GX graphical overview and in VRM? Does it show as an error, greyed out, or simply disappear?
Full recovery — key question: After an extended absence, when the Fronius is reconnected and powered back up, does the entire system return to normal operation automatically — including AC coupling, frequency shifting, and Cerbo GX monitoring — or is a manual intervention required on the Victron side?
Thanks in advance for any feedback or real-world experience on this scenario.
