The manual for my Victron MPPT 250/100 Ve Can says the absorption time should be 2 hrs. Yet the Integrating Simpli-Phi with Victron equipment manual says 6 minutes. That seems to be an awfully big spread between the two. Any reason why?
I cant see in the manual where ir says that 2hrs should be the maximum absorbtion time limit. But in the section about adaptive absorbtion time it says to check the battery manufacturers specifications. Ih that says 6min then its 6min. But i do agree that thats very short. Maybe check the actual spec sheet or ask their support if thats a typo
I see it in page 38 of the manual.
This will be referring to Victrons Smart lithium or NG batteries. The manuals for these batteries goes into more detail. For daily absorption the time is better as around 15 minutes.
I will check that out, thank you!
