So I have a 50 amp RV connection with 2 sub panels one for each inverter.
Would it be more beneficial for the inverters to be setup in a multi configuration vs running each inverter separate and use a mk3 via USB into the cerbo for inverter 2 control.
RV may use a 30 amp or 15amp connection if power is limited.
