300-600w inverter with hard wired outputs?
Greetings from South Carolina! Novice solar guy here and am installing a DCDC charger (xs1400) in my 2025 tundra and will also be using the power wire to run a small inverter when vehicle is running. I have a 110v outlet installed where it needs to be. The power wire will be distributed from a block to the charger and to the inverter.
the inverter inputs are not an issue. However, it seems the smaller inverters only have “outlets” and not connectors for bare wires. The outlet in the truck has three bare wires to connect to.
  • Xs1400 - this unit does not require a trigger wire, correct?
  • What smaller inverter has bore wire outputs to be hardwired?
  • Does suggested inverter need a trigger wiT can offer!
Thanks for any help you can offer in regards to my proposed! System
